My motor is shakin to pieces !
jibbers
Post Sun May 22, 2005 11:31 am
I have a very annoying vibration or resonating prob , when i get between 1.5k and 2.0k this horrendous shake takes place , does anybody know what it could be?
I have had the car on a ramp to find it and i just cant see what it is , nothin seems lose anywhere .
I have a feelin it could be just simple like an exhaust vibe , or maybe the viscous fan is sort of out of balance , but i dont know how to check it out ! !
All suggestions greatfully accepted
Cheers Jibbers
TOURINGDADDY
Post Sun May 22, 2005 11:35 am
Sounds like an engine mount prob to me bloke. only a fiew quid 2 sort but get cheked first.
Ziggy
Post Sun May 22, 2005 1:24 pm
Or propshaft?
Adammcf
Post Sun May 22, 2005 2:21 pm
Engine mount is the most likely source of the problem but as said above check the prop as well.
jibbers
Post Sun May 22, 2005 2:27 pm
Cheers guys , have checked out the mounts and nowt seems to be wrong and as for the prop , it could only be the centre bearing couldnt it ?
Surely if this was shot i would get the vibe right through the rev range , in fact cancel the last point cos it does it in neutral when the prop aint movin , so thats not it !
I was thinkin more along the lines of some sort of engine related prob , maybe the viscous fan ?
Im not sure if its workin right , i.e when it should be spinning , or not !
Its not sumfin i know much about , is there any way to tell if its broke ?
Have noticed a small , well tiny blow on exhaust , but this wouldnt be felt through the pedals and seat would it ! !
Jibbers :?
Ziggy
Post Sun May 22, 2005 2:45 pm
Are you sure it couldn't be a misfire? Would quite likely shake a fair bit if one of the cylinders wasn't firing...
& if you think it's the fan, take it off & see if it still does it!
A1BMW325iSport
Post Sun May 22, 2005 3:34 pm
centre bearing or guibo maybe?
Adammcf
Post Sun May 22, 2005 7:41 pm
The exhaust could have come off one of its mountings and may be touching the underside of the car somewhere and causing it.
TOURINGDADDY
Post Sun May 22, 2005 7:45 pm
No deff not the zorst quite poss the viscus is there any part of the blades missin?????? :? :?
jibbers
Post Sun May 22, 2005 8:16 pm
Nothin missin anywhere , the prob isnt there right away either , after about 5 mins it starts and gets louder as the engine warms , thats why i thought it was maybe the fan , what is it supposed to do and when , i heard it had some kind of clutch in it , is this true ?
Jibbers :?
Karan
Post Sun May 22, 2005 8:20 pm
i doubt its the viscous...... misfire??? mounts?? exhaust?? does the clutch feel normal....
is it only rev related then not speed?
if speed its almost 100% prop related....
does engine pull like normal or does it feel weak?
jibbers
Post Sun May 22, 2005 8:32 pm
dont reckon its the mounts , there is not a misfire , it does it even in neutral , i have just put in a new clutch as i thought this was the prob !
It pulls very well , maybe it is the zorst ressonating , i just dont know ?
Jibbers :?
JungleGus
Post Sun May 22, 2005 8:40 pm
bottom end bearing?
doesnt sound fun
Karan
Post Sun May 22, 2005 8:44 pm
what engine is this???
just go check ure oil level.........
jibbers
Post Sun May 22, 2005 10:04 pm
325 , OIL LEVEL SPOT ON !
Jibbers
