wanna replace the rear coils and drop it 60mm
reckon i need to undo shock, driveshaft and then undo the bolt which secures the trailing arm.
this looks like the springs will then pull out whilst on a spring compressor
reversal for refit
am i dreaming or what >???
seen jobs before that look this simple and yeah i remember them well - doh!
rear spring replacement simple or not ????
Andy335Touring
Remove lower shock absorber bolt and the antiroll bar drop link then either lever out the spring with a crow bar or compress the spring.
And if you have some one to help you get them to stand on the hub.
