Check panel cover, the bit that holds the sunvisers etc
nzracer
Fri Jan 18, 2008 4:46 pm
How the hell do I retro fit the control panel cover? Do I have to strip/cut away the front part of the roof lining?
cheers
Paul
Fri Jan 18, 2008 5:19 pm
No, have you looked at it yet? :?
nzracer
Fri Jan 18, 2008 6:47 pm
yes i had a wee mess with it but it seemed to fit abit to proud. the car it came off had a bit of roof lining missing where it goes mate so sorta guessed mine would have to be the same :?
nzracer
Fri Jan 18, 2008 11:34 pm
bump
Templ8e30
Fri Jan 18, 2008 11:55 pm
Both of my e30's with check control still had the full headlining but with the black moulding over the top, both left the factory like this.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
ucpsale
Sat Jan 19, 2008 12:34 am
Hello, there should be two (o/s &n/s) screw fixings on the panel you want to fit, they secure from the inner sunroof gutter. Then you should have a lip that folds over the roof lining lip under o/s & n/s door sills also lips around roof lining around sunroof. If the screw fixings are missing on the panel, then i am affraid it will never fit correct and no you do not have to cut the roof lining. Thank you
nzracer
Mon Jan 21, 2008 9:45 pm
Ta very much mate
