unknown cable :(
elliot
Post Fri May 20, 2005 1:59 am
any ideas where this white cable came from? not sure if it was connected to anything when i took the cntr console out
elliot
A1BMW325iSport
Post Fri May 20, 2005 2:14 am
prob left over from someones previous stereo install,
i`m pretty sure its not part of the original wiring loom anyway
buster
Post Fri May 20, 2005 5:00 am
you got air con in that convertable aswell ??
Post Fri May 20, 2005 9:15 am
Electric aerial control wire is white.
elliot
Post Fri May 20, 2005 9:43 am
no air con matey. could be the aerial cable, good thought that, its got a spade end on it though which is a bit odd
elliot
BrAdZ
follow it, i expect it will go down the centre of the car into the boot if it does its electric airel or previous ice install
Post Fri May 20, 2005 1:32 pm
Rear speaker wires go back the middle of the car, but the aerial control wire, along with the red power wire, should go back the LH inner cill.
buster
Post Fri May 20, 2005 2:44 pm
so where do those air vents go.They aren't on my heater unit .
elliot
Post Fri May 20, 2005 3:25 pm
buster wrote:so where do those air vents go.They aren't on my heater unit .
i think they are for the under seat heaters that blow into the back.
elliot
buster
Post Fri May 20, 2005 3:36 pm
ive seen those before,i thought that only air con e30's had those though.
You learn something new every day !
Simon
Post Fri May 20, 2005 10:28 pm
buster wrote:ive seen those before,i thought that only air con e30's had those though.
Only in 4 door cars mate (or tourings and cabs) they pop out in the hole in the carpet under the seat. For some reason not fitted to 2 door cars.
