Catalyitic converter issues!!!!
Finny
Post Thu May 19, 2005 2:10 pm
I have just purchased an E30 touring but it happens to be one of the very late ones, L reg to be precise!!! I intend to put the 325 engine from my recently wrote off e30 in asap.
I have some concerns however about the CAT. Does any one know the lwa regarding these because i reckon that i will have to fit one for it to pass the MOT. Is this a correct assumption? i believe that from 1993 or 4 all cars had to have a CAT fitted.
Andy_magic
Post Thu May 19, 2005 5:18 pm
I can't remember the year this law came into effect.
The car doesn't have to actaully have a cat, but it must pass the emissions test which is quite hard without one.
I can't remember the exact specs for cat equiped cars but it is low.
Are you having problems with the cat?
TOURINGDADDY
Post Thu May 19, 2005 8:01 pm
how frendly wid ur mot garage r u. if ur not then u will have 2 fit a cat :cry:
Andy_magic
Post Thu May 19, 2005 9:54 pm
My K plate Sierra twin cam (K reg) should of had a cat according to my MOT testers build data but had been removed ;) it passed ok
Zayyan
Post Thu May 19, 2005 9:57 pm
There was a thread about this problem a while back.
Solution was:
1) Buy MOT tester pint
2) Say "Will you ignore the absence of a cat on my '93 touring?"
Post Thu May 19, 2005 11:26 pm
Problem will arise when the new computerised MOT system gets going (if ever).
You'll have to fit a cat and appropriate ECU, or go for an LPG conversion.
( 7p per mile on a 325 ).
