noisy m10
retroroy
Fri Jan 11, 2008 10:06 pm
does anyone no about m10 engines i have a 316 pre injection when its cold it sounds sweet but when warm its very tapy and seems to hunt as well also what can you do to get more power out of them thanks
Fri Jan 11, 2008 10:10 pm
if its hunting it usually means the carb it shot, the pierburg carbs on them are terrible and best to be fitted with a weber replacement carb, just baught one for mine they just bolt straight on and do away with all the electric stuff which the pierburg has on making it less troublesome :D
if its tappty you might have to adjust your tappets :D
retroroy
Fri Jan 11, 2008 10:15 pm
were would i find one of these carbs also if the carb is shot would it drink fuel mine is very very bad on fuel thanks
Fri Jan 11, 2008 10:21 pm
might be the case but there not very economical anyway the weber replacement should improve economy you could try ebay but your best bet is to start a thread in the wanted section on here thats where i got mine it cost me £25 the only downside with it is you need a manual choke :D
lance1a
South African/Scottish import
Fri Jan 11, 2008 10:24 pm
Hi, You can use a carb from a VW Golf/jetta etc 1.8 (as long as it's the weber one). The Pierburgs are rubbish.
Adjusting the tappets is easy if you have three hands and know how. Though it usually takes a few times to work out how to do it properly. Haynes manual describes how. Weber 32/36 DGV upgrade is good for a few extra ponies. But standard you should be getting about 28/30MPG so don't expect it to get any better:D
BMW E28 528i X2
Merc W126 300E twin turbo
Merc cosworth 190e 2.3-16
BMW E28 525E
BMW E28 M535i
Saab 900 Classic Turbo
BMW E24 Highline Cosmos
BMW E24 Highline silver
BMW E24 Macau Msport
BMW 1972 2002
BMW E36 Alpina B3 3.2 Switchtronic
Renault
retroroy
Fri Jan 11, 2008 10:28 pm
thanks for your help i will look in to it
Fri Jan 11, 2008 10:30 pm
no probs :D
rvrboy
Sat Jan 12, 2008 4:41 pm
Your timing chain or tensioner might be making a lot of your noise.
Cheers gerry
