Instrument cluster question
pmaddy00
Post Wed May 18, 2005 11:20 am
Are they all the same for e30s apart from MPH on the speedo?
Thanx
Borderbmw
Post Wed May 18, 2005 11:27 am
Don,t think so,im pretty sure they are different for 4 and 6 cylinder engines something to do with the signals i think ( :liar: ?)
Post Wed May 18, 2005 2:04 pm
All clusters are the same, and all internal bits are intechangeable, regardless of manufactuer, except for some very early ones.
The coding plug in the lower right front of the cluster is matched to the model of car, and should be retained.
Obviously there are minor differences, like calibrated in km/hr and MPH, and different positions for the tacho red line.
Widge
Post Wed May 18, 2005 2:58 pm
I know you are the guru Brian and sorted me out when I was fed up with my central locking, but you're wrong.
I sold a cluster on ebay the otherday that i got out of a 316i and it had no hole to put a coding plug in, and before you say any thing I had a 318i one as well and it did have the code plug and hole in the front.
They all seem to be slightly different, red lines, max speeds... etc
Demlotcrew
Post Wed May 18, 2005 3:55 pm
Brianmoooore wrote:except for some very early ones.
^^ Widge, i think you should take it back because i know that Mr Mooooore is correct in his wisdome.
Andrew
Widge
Post Wed May 18, 2005 4:11 pm
I would do and I don't maena any offence Brian so I hope none is taken, but this wasn't out of an early car. It was like 89 or somthing.
But I'll apologise any way if it make you feel better :D
Demlotcrew
Post Wed May 18, 2005 4:35 pm
Widge wrote:I would do and I don't maena any offence Brian so I hope none is taken, but this wasn't out of an early car. It was like 89 or somthing.
Dude its possible that someone changed those clocks round, i know for a fact that Mr Mooooor is correct i have gone through about 10 sets of clocks every possible combination.
Just keeping them for spares, as they should be worth something in 15-20 years time.
Andrew
Widge
Post Wed May 18, 2005 4:41 pm
OK fair point, which one would have clocks without a code thingy then seems a bit bizzare considering all the rest have them.
peejay
Post Wed May 18, 2005 6:10 pm
Apparently a DUDE is a camel's foreskin.
You live & learn eh ?
Peejay
peejay
Post Wed May 18, 2005 6:11 pm
Peejay
cros
Post Wed May 18, 2005 8:50 pm
Widge wrote:OK fair point, which one would have clocks without a code thingy then seems a bit bizzare considering all the rest have them.
Was going to interrupt :duck:
Really early ones had the coding plug in the back of the tacho guage. Usually VDO ones with tapering green bands on the tacho face. You can see the obsolete "Codier Stecker" (Code plug) moulding on the back of the later guages.
Certainly would never have been on a 316i from the factory.
