323i diff
dazleeds
old skool raver
old skool raver
Post Tue May 17, 2005 4:44 pm
can i put a c reg 323i diff on my f reg 320i se??
mine whine likes hell also would theyre be any benefit by fitting the 323 unit???
cheers Daz leeds
www.oldskoolfantasy.co.uk
Davenotouring
Post Tue May 17, 2005 4:46 pm
Dunno what ratio the 323 one will be, check the ratio on the tag. Could even be a slipper.
If they are both large case, it should bolt straight up. :)
BMW 328i Cab - Daily Slag
dazleeds
old skool raver
old skool raver
Post Tue May 17, 2005 4:48 pm
how can i tell if its large or small case?? sorry but i got no knowledge when it comes to diffs and ratios will go look at tag now if i can see it back in five Daz
320Touring
Post Tue May 17, 2005 4:49 pm
if yours is a 320 on an f then theres a good chance that its a small case diff....prob a 4.10
if so you need to shorten the prop to get it to fit the 323 diff which is large case iirc
dazleeds
old skool raver
old skool raver
Post Tue May 17, 2005 4:51 pm
damn cant see it prop ill have to jack it up in the morning and have a good look cnt be rs,d now lol
so what should i be looking for on the diff?? cheers DAZ leeds
I may be wrong here, but I am sure I was once told that LSD diffs have either a S or a Z stamped on the casing somewhere? Anyone else come across this? Sure I read it in Practical Performance Car mag, they had an E30 buying guide at the back.
320Touring
Post Tue May 17, 2005 4:53 pm
the LSD's have an S stamped into the casing and also infront of the diff number
S371..... = 3.71 LSD
HTH
Davenotouring
There would be an S in front of the ratio, something like...
S 3 91 xxx
That would mean it was an LSD ratio 3.91
The small case has a different amount of bolts on the cover methinks, but not sure. Someone else will know I hope!
dazleeds
old skool raver
old skool raver
Post Tue May 17, 2005 5:04 pm
cheers lads
will pop out in a bit and jack up just in case it is a slipper then ill swap it tommorow
still need to know how i can tell small from long case diff if anyone knows cheers Daz leeds
ps whats best ratio to have??
Davenotouring
Post Tue May 17, 2005 5:09 pm
3.91 is good.
3.73 is v. rare and a good compromise.
3.64 is good for motorway cruising, maybe very slightly low for acceleration especially on a 320. I can't see a problem with any.
Some were even 4.10, 3.25 (M3).
dazleeds
old skool raver
old skool raver
Post Tue May 17, 2005 9:28 pm
anyone???
as above cheers Daz
astondg
Post Wed May 18, 2005 1:11 am
I thought somebody said that the larger diff has more bolts than the smaller one. That could be wrong though and even if it is right I don't know how many botls on each, might be 6 and 4 or something.
The owners handbook for my 323i says the diff was a 3.45 or 3.25 ratio (some markets) and there was an optional LSD, but doesn't say what ratio for the LSD. Mine was the LSD, I have had the internals changed for a 4.1 LSD now but I think the case is still the same. I can't see what ratio is stamped on it though and I don't have a jack handy. Either way if you had a 4.1 the 323i diff might be too low a number (geared for highway use and high speeds).
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
