320i auto cab with attitude!!!
pompey06
Tue Dec 11, 2007 1:07 pm
car runs sweet as a nut 1 day, then next day misfires and revs up bad all day the next???
spent so much on car and still none the wiser.
went to bmw and they were baffeled.
any clues or help well needed.
E30Mark
Wed Dec 12, 2007 8:31 am
What have you looked at / replaced?
Have you checked the injector wiring beneath the inlet manifold? wiring connector corrodes and breaks down.
Blue temp sender?
Too many things it could be!
First eliminate the wiring to the coil / fuel pump by wiring a length of wire & lamp to each, then place them somewhere you can see them inside. They should remain brightly lit with no flickering. If they stay lit when she is running rough then chances are it's something else.
P.S either loose the avatar or reduce it's size by 50% :D
PM for details
pompey06
Wed Dec 12, 2007 9:19 am
ive replaced, leads ,plugs, dis cap, rotor, blue and orange sensors, crank sensor, fuel regulator.. the injector wires were done last yr. idol control valve has also been changed.
as u can see i have done a fair bit to it.
dont know how to sort the aviator out sorry.
Martinaston
Wed Dec 12, 2007 1:19 pm
When you say it runs bad "all day" do you mean literaly all day or its just a pain to start ?
There is NO nucleus.
Wed Dec 12, 2007 1:29 pm
Loose connector to the ECU perhaps, or a dry joint in the ECU box itself?
pompey06
Wed Dec 12, 2007 1:49 pm
when i say it run bad all day. it always starts first turn of key, no matter wot. but when u try to rev it up, its missin and, it has a job to run on all 6.
pompey06
Wed Dec 12, 2007 1:54 pm
but when u leave it a day or so and not drive it. she drives like a new car for the day. faultless
im leaning now towards fuel pump???
Wed Dec 12, 2007 2:03 pm
E30Mark wrote:First eliminate the wiring to the coil / fuel pump by wiring a length of wire & lamp to each, then place them somewhere you can see them inside. They should remain brightly lit with no flickering. If they stay lit when she is running rough then chances are it's something else.
b4gga83
Wed Dec 12, 2007 2:04 pm
Speedtouch wrote:Loose connector to the ECU perhaps, or a dry joint in the ECU box itself?
Or its given up the ghost.
budgie33
Thu Dec 13, 2007 10:24 am
hi i have 320i and it does the same thing but only when it is cold as soon as it is warmed up it is ok. try to put ya foot down and it splutters and farts at u . its a pain at 5.50 am when i get up to use the car . im gona have a look at that wiring today. :cry:
Thu Dec 13, 2007 10:32 am
budgie33 wrote:hi i have 320i and it does the same thing but only when it is cold as soon as it is warmed up it is ok. try to put ya foot down and it splutters and farts at u . its a pain at 5.50 am when i get up to use the car . im gona have a look at that wiring today. :cry:
New blue temp sensor required.
