fuel pump
after taking the black top casing off, you'll see the top of the fuel pump. note there is 2 gaps in the flanging bits. tap them anti clockwise with a hammer and screwdriver or chisel bit to unscrew. the rest is obvious by looking.
straight forward enough job for most basic home mechanics.
good luck
good luck
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
SPADGE
Remove the 4 nuts holding the fuel sender unit in first and remove it. If you don't remove that on its own you won't get the fuel pump out.
- Brianmoooore
Slightly more involved on a touring. The seat bases, the carpet under the bases and the hinge bar for the seat bases has to be removed first.
