front brakes, 325i on a 318i (what's needed)
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun May 15, 2005 11:09 am
Question is in the subject really. What exactly do i need.
afaik I'd say the following
disks
calipers
new pads (good ones)
new hoses (extra safety)
new brake fluid
bleed kit thing
Are the disks easy to remove? What about the hoses? Do I have to depressurise the system?
are there any other useful things I can do at the same time as this, either brake related or otherwise.
I know I've asked this before but as I'm changing the hoses anyway should I bother with SS ones?
Thanks guys. I think I'm gonna try and do this today.... hope it works as I need the car tomorrow :)
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun May 15, 2005 6:18 pm
I decided to pass on doing it today as I discovered there's some building that sells beer of all things... wow :)
Still anybody got any comment or advice, would be appreciated.
Post Mon May 16, 2005 10:42 pm
Overfill the brake fluid resevoir, put a piece of cling film across the top, and screw on the cap from the clutch resevoir. This should minimize brake fluid loss.
Discs are only held on by a single hex headed locating screw, once the caliper brackets are removed.
You probably won't even need to bleed the brakes as such. Just remove the cling film and open the bleed nipples after you finish, and they will bleed by gravity.
Would be nice to fit the rear discs as well to maintain brake balance, but a much bigger job.
PUMP THE BRAKE PEDAL before you move the car after you finish, to bring the pads into contact with the discs. You wouldn't be the first person to find the brakes don't work the first time you need them.
telski789
Post Mon May 16, 2005 11:04 pm
so whats the difference between the 325 and 318 front discs/calipers?
Andy325i
Post Mon May 16, 2005 11:17 pm
telski789 wrote:so whats the difference between the 325 and 318 front discs/calipers?
318i are solid discs
325i are vented
telski789
Post Mon May 16, 2005 11:22 pm
so are the calipers the same?
Sjoerd320i
Post Mon May 16, 2005 11:24 pm
nope you need the calipers of the car with the vented discs because the vented discs are thicker and won't fit in the calipers of the non vented ones :wink:
telski789
Post Mon May 16, 2005 11:28 pm
now theres a thing,my d plate 325i which ive just put into a g plate 318i,has solid front discs,the same as the 318i!! looks like someone must ahve bunged them on to get it through an mot or somthing!! b*****ds!!!
dazleeds
old skool raver
old skool raver
Post Mon May 16, 2005 11:30 pm
i have a pair of 325ise front calipers if anyone need some Dazleeds
www.oldskoolfantasy.co.uk
Sjoerd320i
Post Mon May 16, 2005 11:38 pm
that's a real bugger mate :x
Andy325i
Post Tue May 17, 2005 7:31 am
telski789 wrote:now theres a thing,my d plate 325i which ive just put into a g plate 318i,has solid front discs,the same as the 318i!! looks like someone must ahve bunged them on to get it through an mot or somthing!! b*****ds!!!
A 325i with solid discs? Holy cow! Do you have the 325i discs on the back?
Thats on a par with what my E30 2.8 will be until I do the brakes/suspension (Standard 320i brakes) Now that will be scary!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Tue May 17, 2005 11:19 pm
Brianmoooore wrote:Overfill the brake fluid resevoir, put a piece of cling film across the top, and screw on the cap from the clutch resevoir. This should minimize brake fluid loss.
Thanks. I feel I should change the fluid anyway, just as a matter of course really... unless there's good reason not to?
Post Tue May 17, 2005 11:23 pm
Brianmoooore wrote:You wouldn't be the first person to find the brakes don't work the first time you need them.
been there done that :oops:
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Tue May 17, 2005 11:27 pm
me too. after changing pads. fortunately I was only creeping it forwards :)
about changing to rear disks. it's far too much for me to do before I have to get the 325i removed but would it be worth taking the trailing arms and other bits off to use them in the future? Really, I'm asking can I take the trailing arms of with a smallish toolkit, and a pair of axle stands?
Andy325i
Post Wed May 18, 2005 12:38 am
:lol: I thought it was only me that did silly things like that :lol:
I soooooooooooooooooooooooo cra*ped myself for a second or so!!!!
Never pumped the peddle and abused the handbrake so much in my life!
