Oil leak front right of engine below manifold from sensor...
stappin
Post Sat May 14, 2005 10:08 pm
Oil leak front right of engine below manifold from a sensor...
What is the name of the sensor and what does it do? I gotta get a replacement as it's p*ssing oil when the engine is running but I dunno what it is :x
Simon
Andy325i
Post Sat May 14, 2005 10:26 pm
Oil pressure switch?
stappin
Post Sun May 15, 2005 7:01 pm
cough bump cough :D
Andy325i
Post Mon May 16, 2005 1:20 am
stappin wrote:cough bump cough :D
:wtf:
stappin
Post Mon May 16, 2005 8:36 am
Is it a hi or low oil pressure switch?
Andy325i
Post Mon May 16, 2005 11:47 pm
low pressure lol
stappin
Post Wed May 18, 2005 10:07 am
It appears the switch has corroded away internally and it is dripping out of the contact when the engine is running. This means I gotta do an oil change but how many litres does the E30 325i hold and what stuff do I need (oil wise)?
Andy325i
Post Thu May 19, 2005 2:38 am
Don't need to change the oil to change the switch, just be quick! but if you are changing it I would recommend a genuine filter and a good quality oil.
Use a genuine switch as well!
I think it holds about 5 Ltrs *CHECK THIS FIRST!!!*
stappin
Post Thu May 19, 2005 1:48 pm
Done seems alright with about 4.5litres . The switch is from G&S and was exactly the same make and model number as the original BMW one.
Andy325i
Post Fri May 20, 2005 12:37 am
cool :)
