Post
Sat May 14, 2005 7:55 am
E30's don't have a voltage regulator for the dash (not one you can replace anyway). The temp gauge reading left of centre sounds normal, so I should not worry about that.
When you say the OBC display is 'dim'. Do you mean that it's virtually unreadable and only visible in bright light, or that it's a bit dimmer than normal ?
If it's virtually unreadable, then it's probably the OBC backlights that have blown (common problem). These backlights are mounted in a white plastic housing that slides out from the side of the OBC. It's a bit tricky to gain access if you have never done it though.
You have two options on replacement:
1 - Go to the dealer and swap a crisp Ԛ£20 for a new backlight
2 - Replace the two 5 volt bulbs on the original for a few pence.
Cheers,
Ian.
