18is peterol leak
BadDave
Not to familiar with the I.S. motor
I know on the M40 and 6 pot engines the fuel pipes that go to the fuel rail and pressure reg can become cracked/brittle with age and start leaking
May be worth having a look there 1st
HTH
Dave
HTH
Dave
- anisotropy
Its a classic M42 leak. Those metal pipes join to short bits of hose. Remove throttle body and inlet manifold. You will then be able to see the fuel rail. On the right two short bits of hose connect to it, these will eventually go and can be easily replaced.
