Guess what - I still managed to snap off on of the studs
Can I just replace the stud?? If so is it an easy job?? Any ideas how much oil I'll get through before I can change it????
Your help would be much appreciated.....
The rocker cover studs should only be done up to 10Nm, not 11 lb ft. This may be why you broke it.sabrje wrote: So I used a torque wrench set to 11 lb ft as suggested in Bentleys.
Guess what - I still managed to snap off on of the studs![]()
