318is exhaust replacement
If you don't plan on holding onto the car, you could get yourself a Bosal system, which will include the back box and middle box together as a single unit for reasonable money. If you want a proper exhaust, you can still buy original ones from BMW, not cheap, but what you pay for is what you get...
Try here, you will have to flatten a short section of the top of the pipe, near the hanger, you'll see what i mean when compared to the BMW item, it touches the cross member otherwise. No real bi deal and cheap. This is the Bosal system.
www.leisureshack.co.uk
An E30 touring, two E28 M5's and an E28 528i.
Like has been said theres no real way out of this BMW is expensive and the after market ones are shite and rub on the bottom of the car and are not a good quality.
I have just fitted a Walker universal silencer available from your local motor factors for about £ 38.00.
I cant remember the part No. but it is at the front of the Walker catalogue.
It requires a bit of tube of the correct size fitting in front of it and a hanger but it works very well.
It is a straight through box so is a bit noisier than standard.
318 is.
