Removing parts on convertible
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Post Thu May 12, 2005 3:27 pm
Can anyone give advice on how to remove the strip of plastic in the top pic without breaking the clips off inside it?
:thumb:
nav786
Post Thu May 12, 2005 3:30 pm
the only thing you can do is just pull it slowly from one end.
FOR SALE
SONY PSP'S £100
E30cabalan
Post Thu May 12, 2005 5:12 pm
Its easy, put some masking tape on the paintwork first at one end then gently priseit up from one end.The white clips stay in place on the sill.
If you want to take them off you push the centre of them which pushes a little plastic rod inside the sill. If you take the plastic sill protector off the holes are big enough to retrieve them with a coathanger (straightened out)
and a blob of evostick on the end. It works for me....and the evostick.
Good Luck
William
Post Fri May 13, 2005 12:48 am
great cheers guys
:thumb:
