Pre facelift chips???
big_jof
All the gear - no idea !
Thu Oct 25, 2007 6:11 pm
Probably been answered a million times before but anybody know the deal for chipping early 325's. More to lift the limiter as I've been told it cuts in before the top of the power. :mad:
Ant
Retired Team Member
Retired Team Member
Thu Oct 25, 2007 7:54 pm
early 073 M1.1 chips easily, limiter is there for a good reason on these, the TDC pin on the flywheel tends to depart at over 6.5K rpms.
Gains to be had but dont chase rpms, the stock M20 has given its best by 6200 rpm dude.
big_jof
Thu Oct 25, 2007 10:06 pm
Not losing the TDC pin seems like a good reason for the limiter. I assume you need the Ecu number to supply chips.
This week I've mostly been on honeymoon!!!!
West yorks meet 2nd of each month near showcase Leeds PM or see meets and events.
d6dph
Thu Oct 25, 2007 10:18 pm
Dude, Could you reduce the size of your sig please. Waaaaaaay too big I'm afraid.
big_jof
Thu Oct 25, 2007 11:17 pm
Working on it - how do you preview it without posting / best pix size?
d6dph
Thu Oct 25, 2007 11:21 pm
Start a test thread, There is a section for it towards the bottom of the main forum boards.
big_jof
Thu Oct 25, 2007 11:25 pm
Redone - ok? :?
Thu Oct 25, 2007 11:53 pm
Seems to have disappeared completely, except in one post. Strange!
325ie30
Tue Oct 30, 2007 10:39 am
Sorry to barge in here but about the original question:-
I also have a pre-facelift 325 and have also been wondering about chips. Would it be wiser to chip it as it is OR (as I think I read somewhere on here) would it be better to convert it to the facelift ECU and chip that? If so how difficult would that be? It's primarily a track car if that makes any odds.
Ant
Retired Team Member
Retired Team Member
Tue Oct 30, 2007 6:06 pm
you can chip what you have or swop to the later Motronic setup, having no TDC sensor to come adrift from the flywheel might be a good idea.
Both offer great scope for tweaks as both are fully 3d mappable fuel and spark.
swopping in the later setup is Loom-ECU trigger wheel for front of engine, crank sensor pickup and swoppping a couple of wires on the C101 connector, you can get all you require from any 6 cyl plastic bumper car ( sept 87 onwards.. )
:thumb:
325ie30
Tue Oct 30, 2007 11:45 pm
Cheers Ant, if there's no big advantage to using the later setup then I might do myself a favour and not make extra work for now, especially since I've only just got the thing fixed up and MOT'd.
I understand you're the guy to talk to regarding getting the right chip - I'll be in touch when the time is right :D
daveyboy20
Wed Oct 31, 2007 3:46 pm
sorry to hijack the thread! I have a 320i early e30 b reg chrome bumper. What options do i have when it comes to chipping? Im new to ECU's and injection! cheers chaps
A1BMW325iSport
Wed Oct 31, 2007 4:00 pm
with my old 320i i got a performace ecu, can't remember the company that did them but it made hell of a difference
daveyboy20
Wed Oct 31, 2007 5:46 pm
Oh right - how much was it? did it affect fuel economy or anything?
A1BMW325iSport
Wed Oct 31, 2007 6:47 pm
wasn't cheap iirc was 275quid!!! yes it did affect fuel economy but i wasn't bothered about that, gave it a few bhp and the throttle response was much improved.
someone on here had the ecu off me but it was ages ago, i'll try dig some info up if i can remember the name of the company
Ant
Retired Team Member
Retired Team Member
Wed Oct 31, 2007 7:32 pm
daveyboy20, you cannot chip the LE Jetronic system you have dude, there's o provision for that to be done, replace with the later motronic or add a standalone ECU to suit
daveyboy20
Wed Oct 31, 2007 8:07 pm
Oh i see, cheers mate - as i say im new to all this technology gubbins! Im used to carbs and points!
