BREMBO??
jamie325isport
Post Sun May 08, 2005 9:23 pm
Would i be able to fit these to my sport??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 28702&rd=1
Thanks guys.
Wanted:- One Genuine 7J Alpina. PM me
Turbo-Brown
Boost Junkie
Post Sun May 08, 2005 9:43 pm
Might have trouble with the discs, but fitting the calipers is just a case of making up suitable brackets and then plumbing them in.
If you've got some manufacturing facilities/contacts then there's no reason why not (although you would need to source some different discs as those almost certainly wouldn't fit on the front even if you did have 5 studs)
jamie325isport
Post Sun May 08, 2005 9:46 pm
I know the discs wont fit it was the calipers that i was interested in any idea where i would be able to get some to fit any ideas?
iKst
Post Sun May 08, 2005 10:39 pm
You can redrill discs to fit 4x100 pattern.
Turbo-Brown
Boost Junkie
Post Mon May 09, 2005 8:14 am
Problem with those discs is that the dish of them would almost certainly cause them to clash with the track-rod ends.
You could probably get some of the 280mm discs that Rally design use with the Wilwood kit. They sell these seperately if that's any help?
MONSPORT42
Post Mon May 09, 2005 3:22 pm
The wheel size/offset is usually the main problem with fitting non standard calipers - if there's enough room you could almost certainly get them to work with some inginuity and patience!
YOUR LEFT FOOT'S FOR BRAKING
