Remove the clear plastic cover and cluster gauge from e30.
Rkive
Fri Oct 12, 2007 1:52 pm
How do I remove the clear plastic cover and cluster gauge from my e30?
FWD is for Pussy's
StuBeeDoo
Fri Oct 12, 2007 1:54 pm
Do you mean the instrument panel???
Rkive
Fri Oct 12, 2007 1:58 pm
Possibly, I have this and I have been told I need to remove the clear plastic cover and cluster gauge to fit it.
FWD is for Pussy's
Fri Oct 12, 2007 2:19 pm
It's glued on, but I've removed a few by carefully levering around the edge. I fit the alarm/immobiliser LED in there.
Rkive
Fri Oct 12, 2007 4:08 pm
I thought there were screws?
FWD is for Pussy's
jcjdavis1
Fri Oct 12, 2007 4:21 pm
Rkive wrote:I thought there were screws?
x2 Do you mean the cover over the dials or the facia around the dials?
Rkive
Fri Oct 12, 2007 4:26 pm
I don't know, but what is the easiest way to get the clear plastic cover off? Do I need to take other things off to get it off?
FWD is for Pussy's
Rkive
Fri Oct 12, 2007 4:43 pm
It should be easy but it aint, can anyone help?
FWD is for Pussy's
JimmyC
Fri Oct 12, 2007 4:57 pm
Its as Brian says, once you have removed the cluster (6 screws in total I think, inclusing the trim screws)
You will need to remove the plastic to fit that in, which is as said above glue on- its a PITA or really easy, I've had a few just pop off, others that have been a mare!
Chris-W
Fri Oct 12, 2007 7:29 pm
You need to remove:
Underdash panel (3 x plastic twist screws)
'fillet' beneath cluster (2 x knurled bolts behind)
4 x small phillips screws at lower edge of instrument cluster shroud and 2 x at top
Then 2 x phillips screws holding cluster into top of binnacle hole
Much easier with the steering wheel off, btw.
tommype30cab
Fri Oct 12, 2007 8:48 pm
hi this is usually a pain but if you use glue or any type of solvent dont touch anything inside the cluster cos fingerprints turn to white and are very hard to remove, good luck.
"Racing is life. Anything that happens before or after is just waiting" Steve Mcqueen
