How to Remove Front indicator Tech 1
As the Title Suggests i need to remove the front indicator on my Tech 1, as some pigeon felt the need to commit suicide my flying into it destroying pretty much all of it, ive looked for screws and tried tugging a bit but i cant fugure it out. any one know what i need to do. im sure its easy when you know how but i obviously dont
Do you need to remover the whole thing or just the lens? Im assuming the whole thing as the lens has a screw either side which is obvious.
You'll need to remove the whole bumper im afraid. Nice and easy though. Just undo the 2 large bolts behind the small square plastic covers on the front of the bumper (number 7 in the 1st image below).
Then there should be one bolt on each side under the wheelarch holding the sides of the bumper to the wing (number 7 in the 1st image below). Youll need to remove the plastic arch guard to get to it.
Then the the whole front bumper and skirt will come off. Now you just have to undo the 2 7mm bolts from the rear of the indicator housing holding it to the bumper (number 6 in the 2nd image below)
