Touring Rear Washer Motor Leaking
Hutch4161
Sun Oct 07, 2007 1:23 pm
Hi
Rear washers are not working on my Touring, traced the fault to the rear washer motor (it was blocked with rust & cleaned this out), where the washer pipe goes into the elbow on the motor, it's leaking water there, can this be fixed or is a new motor required ???
Tom
BadDave
Sun Oct 07, 2007 3:59 pm
If it's the actual plastic elbow then it can be superglued back on.
If it's where the pipe fits over the elbow then trim about 1/4" from the endof the washer pipe and then refit it.
