JUDDER btwn 40 and 60
Guest
Post Wed Jan 19, 2005 1:52 pm
My newly acquired 320i Convertible (1990) has a judder to the steering bewteen 40+60mph. I have just had the wheels balanced and tracking done when tyres were chaned today but the judder is still there. Any ideas. PS the wheels/tyres are non standard 205/17/45's.
Also anyone know of leather timmers in the wirral/cheshire/merseyside area?
Many thanks,
G. :roll:
cros
Post Wed Jan 19, 2005 2:59 pm
Long answer: could be a flat spot or even an axial runout on the rim. Or a badly made tyre. Or bad brake discs. Or worn steering/suspension bits.
No amount of balancing (hanging weights off the rim) will compensate for non-circular wheel. A wheel balancer just distributes centrifugal force evenly over the rim (the wheel has no vibration when spun in the air). If the distance from the road to the axle isn't constant, then you'll still feel a vibration.
You can guage this by watching the wheel on the balancer - any kicking will be obvious there. You can see if it's the rim or the tyre too. It is possible to straighten small flat spots with with a hammer (even on an alloy) using a phone book between the two to dampen the impact. You could end up making it worse just as easily though!
A bad wheel isn't nearly as noticible on the back axle, so try juggling them around.
Guest
Post Thu Jan 20, 2005 10:16 am
Thanx for that I will see if it makes any difference.
Cheers,
G. :)
parksie
Post Sun Feb 20, 2005 11:27 am
hi mate
only joined today,no expert on the 3 series butwhat i do know is that if you've gotnon standard wheels, then check the diamiter of the hub and wheel centre, if not a snug fit then you can buy some hub rings.
and no more probs
BenE30
Post Sun Feb 20, 2005 11:33 am
I used to get that on my iS anf it was the prop shaft mount! once that was replaced HEY PRESTO!! problem solved!!!
Hope this helps!!
low325icab
Post Sun Feb 20, 2005 12:03 pm
have you got alpina reps on there by any chance? as ive found that on the set ive got, ive had them on two of my e30s and both cars have had the same prob as your having and at the same speeds too.
johnono
Post Sun Feb 20, 2005 12:04 pm
That one, That one, That one, That one,
(mateys avater :lol: )
low325icab
Post Sun Feb 20, 2005 12:21 pm
johnono wrote:That one, That one, That one, That one,
am i being stupid here?? what you mean
johnono
Post Sun Feb 20, 2005 12:29 pm
bensԚ´avater!
dont know what series its from, but the sketch i recognise :lol:
i can just hear him , that one.
p.s, pc is on a go-slow today.. has anyone else notices it or is it just me
BenE30
Post Mon Feb 21, 2005 5:49 am
johnono wrote:bensԚ´avater!
Lou and Andy off Little Britain mate!! :D :lol: :D
johnono
Post Mon Feb 21, 2005 10:54 am
ThasԚ´it :D
saw a couple of em, but that bald dude is so funny. i remember him from never mind the buzzcocks?
Guest
Post Mon Feb 21, 2005 12:12 pm
check the lower arms?
LOW
Post Tue Feb 22, 2005 12:59 pm
I had this problem on my 325 running on a set of 17 inch BK's, when i returned the car to its std wheels the problem disappeared but then again so did the rims! :cry:
