tempramental 325!!!
- TOMMYSPANNER
CHECK POSITION REFERENCE ANDCRANK SENSORS AS COIL IS ONLY ENERGIZED ON THEIR COMMAND ALSO DOWELS ON THE E30 325I WHICH THE SENSORS PICK ON CAN FALL INTO THE BELL HOUSING HOPE ITS NOT THAT ALSO HAD SAME PROBLEM NO SPARK IT WAS THE HYBRID SWITCH WITHIN THE ECU IT HAD A BOSCH PART NUMBER GOT THE BIT DE SOLDERED THE OLD /SOLDERED THE NEW 100 PERCENT HOPE THIS HELPSCAN MAYBE FURTHER ASSIST AS IAM ALSO A MECHANIC TOMMY SPANNER PORT GLASGOW WHITE WATCH ON E MAIL rosaline.finney@ntlworld.combest of luck mine is a e30 325i
Got the same problem with my 325 tried every thing includeing ecu aind crank sensors still not starting looking into the wiring at the mo maybe a imobaliser thats been disconected in the past has kicked in.
