oil light..
Hath
Mon Sep 10, 2007 8:51 pm
ok after having an aweosme day yesterday.. fixing ym car upto mot stanadrds etc.. i ahve found a problem today whihc quite frankly has stumped me...
oil light has come on.. now the engine isnt starved of oil.. it has plenty of oil as done an oil change yesterday..( light only came on today)
aroudn the connecotr its a taddd oilly and moist possbly from spilling some oil when removing the old filter..?
anyone shed any light as im quite frankly stumped..
Hath
Mon Sep 10, 2007 9:17 pm
Gwynleym10
Mon Sep 10, 2007 9:28 pm
I would clean around the oil sensor, if it really dirty. Take it out etc
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
Hath
Wed Sep 12, 2007 8:54 pm
still haveing trouble.. would the filter be a problem for the oil light to come on.. as the filter i have is a slightly diffrent one to the one that i took out.. ie the one tha ti took out had a metal sheef around it with holes in.. an the one i stuck in was ltierlaly a filter type.. wiht a metal sheef on the insdie what is the possible causes to the oil light comeing on..? i only undone two blodoy things sump plug and oil fitler houseing..:S i have no il leaks.
Hath
Wed Sep 12, 2007 9:06 pm
also was an automtic before with an oil cooler in the rad...??? possible problems?
Hath
Wed Sep 12, 2007 9:24 pm
i used 10w 40 oil aswell? is this.. a problem? i cnt make head to tail fo the reccomended stuff in the owners manual its a M42 is engine
HairyScreech
Wed Sep 12, 2007 9:40 pm
try sticking the old oil filter on and see if this cures it. cant hurt to try,
Wed Sep 12, 2007 9:50 pm
Pull the connector off the oil pressure switch as carefully as you can, without disturbing the wire any more than possible. Does this make the light go off?
The oil pressure switch wire runs around the front of the engine where the insulation gets brittle and falls off, or gets damaged by the water pump pulley, and if it shorts to earth the oil light will come on.
Oil pressure switches can fail quite readily as well.
Hath
Wed Sep 12, 2007 9:57 pm
i took the connecotr off and hte oil light went out and stayed out..
Wed Sep 12, 2007 9:59 pm
Hath wrote:i took the connecotr off and hte oil light went out and stayed out..
Time for a fresh switch then. If that doesn't cure it, time for a fresh engine.
Hath
Wed Sep 12, 2007 10:00 pm
what... fresh engine :| ive only jsut swapped it for a horrid m40 auto engine its a m42 manual now.. grar
Wed Sep 12, 2007 10:05 pm
You'd better hope a fresh switch cures it then! Any engine that doesn't produce enough oil pressure to make a good switch turn out the pressure light isn't going to last long!!
Hath
ah fuckety fuck fuck, if it doesnt cure it.. its going the right way for a 6 pot!
munky30
100% Pure Council
Wed Sep 12, 2007 10:13 pm
surely it wouldn be the pump if it wasnt the switch? No need to replace the whole engine?! :? There must be a reason its not getting pressure...
