Hand brake button missing
greentouring
The little button on the handbrake seems to have disappeared. To use the hand brake I have to squeeze my finger into the hole where the button was to release or raise it.
Anyone else had this problem?
At first it felt the button was there, but had somehow sunk inwards, inside the hand brake, but guess this couldn't really happen..................
greentouring
Umm, not sure I know what you mean, mate.
greentouring
Pal, not it hasn't.Pal318is wrote:Has the actual handbrake lever itself been pushed forward by accident??
HTH
Pal
Martinaston
Push the plastic grip back down the lever
There is NO nucleus.
Pal318is
- Contact:
That's kinda what i was thinking tbh...It happened to me, i thought, where the hell has the button gone!Martinaston wrote:Push the plastic grip back down the lever
Pal
Pal
[img]http://
[img]http://
FIREBREATHER60
i had it on mine two days ago push the plastic handle back you might need to twist VERY slightly but you will see the button re appear. i had it on a work van too!!
greentouring
Right, how embarrassing if it turns out to be that!
But a saving, so it's all good.
It's put away under a cover at the moment, so will look tomorrow.
greentouring
Haha! Yeah, it worked. How that moved so far I have no idea, as it certainly isn't loose and it took a lot of persuasion to move it back down and expose the button, but it's done now anyway!
Thanks fellas!
Thanks fellas!
- m7roadrunner
goin out to fix mine now
