(hoping the latter!
clock bulb change.
Borderbmw
To change the bulb in my analogue clock,does the clock have to be unscrewed from the back of the panel or does it just unclip and slide out from the front?
(hoping the latter!
(hoping the latter!
Davenotouring
You can't just pull it out from the front, it's held in by four small phillips screws from behind.
If you take the plastic cover off from the right hand side when you open the glovebox, you should be able to get to it.
BMW 328i Cab - Daily Slag
smithy318i
Sorry dave but your wrong
The front black plastic unclips from the front and there is a small plastic tag at the bottom which you push in to remove the clock.
