Stuck Fuel Pump????????????
jimmyj
Taking the fuel pump out (in tank type) undone pipes, twisted it and its come out about an inch but is stuck nfrom there. any ideas as were gettin propa pi**ed off!!!
gorgeee
hahaha i totally know what you mean as i done mine last week but you have to undo the 4 little bolts and take the fuel sender of 1st (just pull it upwards)and then the pump will come out
its bit harder to screw pump back in as the new rubber ring is obviously slightly bigger as its not be fitted
hope that helps
hope that helps
Black Sport
jimmyj
cheers, i must of been fiddling with it for about an hour, didnt wanna undo the bolts incase something fell in the tank!
