rough idle? not always icv!!!
gotoneagain
Sun Aug 12, 2007 4:45 am
did the obvious and changed the idle control valve to no avail, so removed throttle body and removed cover from the throttle position switch it was caked in oil and was not adjusted correctly as it would not click back after throttle had been opened making the engine think is was on part load when in fact it was trying to idle, its much better now, there are loads of threads about this but what you really need to do is strip these components down and clean them out, the problem wont go away without it!!
Sun Aug 12, 2007 9:55 am
Rough idle is very rarely anything to do with the ICV.
A worn and sticking ICV makes the car idle smoothly at various incorrect levels, and a faulty one often results in a wildly surging idle.
There are various reasons for a rough idle, but one of the principal ones is that the ECU doesn't know the engine is at idle. I.E. Faulty throttle position switch.
Low_E30
Sun Aug 12, 2007 12:24 pm
what is the easiest way to access the throttle position switch?
can it be accessed without the removal of the throttle body?
Also how would i know if it was dodgy, would i have to buy a new one to see if worked better?
Cheers Dee
E30 BMW 325i Cabriolet M-tech1 + Hardtop
W201 Mercedes 190E 2.5-16
W124 Mercedes E220 AMG Cabriolet + Hardtop
S124 Mercedes Estate AMG
C126 Mercedes 500 SEC
W210 Mercedes E55 AMG (2001 Facelift)
Jaguar XJR Supercharged (2002)
Sun Aug 12, 2007 1:49 pm
Low_E30 wrote:what is the easiest way to access the throttle position switch?
Cheers Dee
Take the big air hose off to get at it.
Use a meter to check resistance between the pins as you move the throttle.
murran
Sun Aug 12, 2007 8:35 pm
with the switch being underneath the throttlebody id just take the body off the engine so you can see what your looking at and clean it and adj. it properly. also inspect the wires as just into the wiring loom of the three pin plug on my 320 throttle switch, i found a broken wire!!
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
