Removing my 2.0 and ive given up for today as i cant for the life of me get one of the torx nuts out of the bell housing/block.
Haynes manual says long bar & swivel even thats a nightmare.
Torx Nuts On Block
m1key
E30Adam
If its the very top bolt then get yourself a set of torx spanners from somewhere and undo it fromt he top using the handle of a trolley jack for leverage.
I've done it this way every time and you can just about get the spanner on the bolt head. Makes life 10 times easier.
Turbo-Brown
- Boost Junkie
God knows what haynes were thinking when they put that in cos it's practically impossible!
I ended up pulling the whole engine and gearbox forwards so i could get a breaker bar and torx socket in there (although the torx spanner method sounds like a better bet!)
