Windscreen wiper motor nearly caught fire.
Jesus325iTouring
- Frog freak !
As in title,the missus was out in the car yesterday when I get a phonecall.
Missus: "There is steam pouring out the car and it stinks of burning rubber!!!!!!! Oh and the coolant light has just come on"
Jesus: "F uck shit f uck b ollocks!!!! Be there in ten minutes"
That ten minute drive saw me panicking that the engine has just been cooked,burning smell,steam and coolant lights,however...
When I arrived,armed with 10 litres of Tesco mineral water I discovered the "steam" was in fact smoke,and the burning smell was rubber.The coolant light was just coincidental thank goodness.
Smoke was pouring out the scuttle grill and I discovered the wiper motor had nearly caught fire,it was extremely hot and all the rubber case had melted.
The wipers were not in use at all,nor had they been that day,my question is why or how could this have happened?
Any ideas?
Any ideas?
Jesus325iTouring
- Frog freak !
No fella,wiring all appears ok,not melted.
Anyone else any ideas?
I think there is a live feed to the motor even with the wipers switched off ( to finish the sweep) The mechanism may have got jammed just before the cycle ended so was recieving a feed and not rotating, This could have heated it up to the point of melting. I am now donning a flame suit in preperation for the onslaught of Brian Moore.
john
john
Jesus325iTouring
- Frog freak !
Ah,could be that John,the wipers have not rested properly for quite some time,so may be this was the final straw.johnl320 wrote:I think there is a live feed to the motor even with the wipers switched off ( to finish the sweep) The mechanism may have got jammed just before the cycle ended so was recieving a feed and not rotating, This could have heated it up to the point of melting. I am now donning a flame suit in preperation for the onslaught of Brian Moore.
john
Bring on Brian
Simon
- Contact:
I'd go with the motor being jammed too, but then surely the fuse should pop before this happens...
Whichever way, get that motor out, check the wiring over, and get a replacement in there right away!
Jesus325iTouring
- Frog freak !
John........how?............why?.........what were you doing to put the wipers on and hold themjohnl320 wrote:You can stop the blades and hold them and the fuse doesn't pop. Found that out the hard way.![]()
john
Got a new motor on order from Spadge,mines disconnected now............please don't rain....................Simon wrote:I'd go with the motor being jammed too, but then surely the fuse should pop before this happens...
I was suprised the fuse didn't pop aswell,better check i've the right one fitted.
Jesus325iTouring
- Frog freak !
PMSL,kids,gotta love 'em!johnl320 wrote:Bonnet open, coat on windscreen, five year old in drivers seat, first thing I notice is a wisp of smoke from you know where![]()
john
Jesus325iTouring
- Frog freak !
How did you get it of the scuttle? Looks bloody awkward to get out
Remove the plastic loom cover thingy just under the bonnet to slide it out, once you've undone all the nuts etc.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
Jesus325iTouring
- Frog freak !
Ah,I didn't notice this cover thingy.Thanks fella316eyes wrote:Remove the plastic loom cover thingy just under the bonnet to slide it out, once you've undone all the nuts etc.
