m3 struts
- Homo Hair
Just a quick question.. are m3 struts the same as the 51mm m-tech/325i ones? Would 51mm dampers fit?
- Homo Hair
just had a look n they are different.. are the wheel bearings the same ie could you fit the hubs off an m3 into 51mm strut?
jmc330i
No, the front wheel bearings are different between M3 and say a 325i. But the rear wheel bearings are the same, so you could in theory fit the M3 rear hubs.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
jaistanley
I was of the impression the inserts for an M3 would fit a 325i hub, ie they are interchangeable. They are probably different parts, but I think you can fit struts intended for an M3 to a 325I (obviously the hub is different giving 5 stud etc,I'm just talking inserts here).
Now, I dont know this for fact, my friend with an M3 recently assured me I could fit the same struts as his M3 (Bilstien sports) to my 318is...
Anyone else shed any light?
Jai
Jai
Andy325i
jaistanley wrote:I was of the impression the inserts for an M3 would fit a 325i hub
Jai
The E30 M3 shocks sure will fit into E30 325i legs
- Homo Hair
Excellent cheers fellas
Karan
m3 struts are completely different as the arb droplinks attach to the strut on the m3 stuff and wheel bearings are different etc....
struts may be interchangeable though
- Homo Hair
yeah.. Its all good for what im after tho.
