what other BMW LSD's fit my e30
gorgeee
Tue Jul 24, 2007 10:32 pm
does anyone know if a e28 535i diff fits my touring?
or if any other diff from another bmw will fit??
Black Sport
Nelly
Gumbo
Gumbo
Tue Jul 24, 2007 10:48 pm
Yes the E28 diff's fit into E30's - all you need to do is swap over the back plate
"I F**KING LOVE YOU GUMBO"
dips346
London Meets Main Man
Tue Jul 24, 2007 10:50 pm
Nelly wrote:Yes the E28 diff's fit into E30's - all you need to do is swap over the back plate
m20 engine e28 fit pretty sure the m30 are different
BM_Jay
Tue Jul 24, 2007 10:53 pm
hi my mate fitted a Z3 2.8 diff on his. Fit straight on.
gorgeee
Wed Jul 25, 2007 1:52 am
but the z3 2.8 aint a lsd is it?
will the e28 m535i diff not fit then?
thanks for the help im just stuck and cant get a decent LSD with a high ratio
i want something like a 3.25 ish but cant get hold on anything like that on a e30 as the m3 are too rare so need to look further a field
Black Sport
Jonsku
Wed Jul 25, 2007 6:45 am
E28 535 LSD doesn't fit E30. It's double the size of E30 big LSD 8O
E28 "small LSD" (all other E28 than 535 and M5) fits by changing the back plate.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Jonsku
Wed Jul 25, 2007 6:46 am
All z3 coupes have LSD as standard. Not sure that they fit E30 but i've a feeling that they fit. They have also the cooling fins on their back-plate.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
gorgeee
Wed Jul 25, 2007 11:48 am
i thought lsd was an option on z3's ?
Black Sport
Dave_M3
Wed Jul 25, 2007 3:27 pm
I'd say they'd definitely fit as in fairness they have the same rear axle as an E30. Z3M bushes fit on the E30 diffs too so theres no reason why one wouldn't just bolt on :D
gorgeee
Thu Jul 26, 2007 11:07 am
i know they fit just didnt think they were all lsd's thought some are open diffs?
Black Sport
kevo
Thu Jul 26, 2007 12:05 pm
i have a 3.38 lsd available. pm if your interested
Kev
Thu Jul 26, 2007 1:57 pm
AFAIK, 2.8 Z3s have Torsen LSDs as standard.
The one I bought (£40!!) definitely is, and fits straight into an E30 without modification.
The one I have doesn't have the finned backplate, and, AFAIK, only came on the Z3M.
Ratio is 3.15:1
gorgeee
Thu Jul 26, 2007 9:59 pm
whats a torsen diff as i went to see 1 the other day and as i turned the input shaft and held 1 of the outputs, the other output turned and this isnt possible on my standard e30 lsd
so is that torsen?
oh and thanks for the help lads
Black Sport
Thu Jul 26, 2007 11:35 pm
Torsen diffs work in a different way to clutch pack type LSDs, and can't be identified by the methods that work for those. You need to open it up; then you can see all the helical gears.
A conventional LSD would 'fight back' against modern traction control systems.
(Torsen = torque sensitive).
gorgeee
Fri Jul 27, 2007 12:14 am
kinda feel abit silly now as i went to buy a z3 2.8 diff the other day and as i did what i thought was the right test i didnt buy and acused the guy of time wasting
so am i right in thing if you turn the input,both outputs turn in same direction then its a lsd?
Black Sport
Fri Jul 27, 2007 12:32 am
I couldn't see any way of identifying a Torsen LSD from the outside. I could only confirm what it was by taking off the cover.
gorgeee
Fri Jul 27, 2007 12:43 pm
is there any markings or the S on the tag?
Black Sport
Fri Jul 27, 2007 1:59 pm
Not on mine.
