suspension - 1.8 and 2.5 the same?
samcoombes
Post Mon Apr 25, 2005 9:41 am
As in fitting, will mtech shocks from a 1.8 fit on a 2.5?
sabrje
Post Mon Apr 25, 2005 9:57 am
Pretty sure they are different - the 2.5 ones uprated in comparison - to take account of the extra weight of the 6 cylinder engine.
Can anyone else confirm this?
samcoombes
Post Mon Apr 25, 2005 10:09 am
hmmm, I thought maybe the spring was a bit firmer to compensate for the weight?
Basically want to buy these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... eName=WDVW
Please nobody hijack them from me :cry: :(
iKst
Post Mon Apr 25, 2005 10:10 am
There is a difference in front shock housing. 325 and some 320 models have 51mm housing and other models have 45mm. Also, what sabrje said. I dont know the exact difference in stiffnes but there are different models of shocks and springs for 6 cly. and 4 cyl. cars.
Jimbob
Post Mon Apr 25, 2005 12:42 pm
hah that's my old set from the iS..
Is your suspension shagged then sam? your Sport will have the same set up (apart from stronger front springs for the heavier engine) so if you are havin probs then it's probably bushes.
samcoombes
Post Mon Apr 25, 2005 1:12 pm
well the fronts are fucked. every bump they knock and rattle.
Andy325i
Post Mon Apr 25, 2005 9:50 pm
samcoombes wrote:well the fronts are fudge. every bump they knock and rattle.
Top Mounts ok?
samcoombes
Post Mon Apr 25, 2005 11:00 pm
they seem it, although after checking the enigne mounts earlier today I think i've found the problem 8O
Jimbob
Post Mon Apr 25, 2005 11:22 pm
8O
