automatic cant get no motion
gotabmw
- Location: Peterborough Cambs England the world the milkyway the universe
went out to drive my bmw 318i auto stuck it in drive no movement tried all other gears still no movement unless i reved it to 4000rpm then it just crawled along checked the fluid empty not even showing on stick will this have damaged the gearbox and i was driving it earlier today with no problem atall is this normal
gra325i
- E30 Zone Meets/Events Team
when you put in the new fluid you will need to bleed the box so as to fill the torque converter and get rid of air better check you havn't blown the gasket too before you fill it..this'll help..
HTH
HTH
