What prop do i need m50 people?
brian325i
Sat Jul 07, 2007 6:27 pm
engine started woohoo!!
i have an e36 325 box, my diff is an e30 4.10,i have a few props around the place,
anyone here have an e36 325 box on there m50..What prop ye using
Sat Jul 07, 2007 11:57 pm
Depends on what output flange is on the gear box. I had a prop shortened/flange changed and balanced for £55 so it doesnt seem worth mixing them up if you have a place that can do this close by.
Sun Jul 08, 2007 12:03 am
Gearbox output flange will be a an E30 sized one with M10 bolts, a similarly sized one with M12 bolts, or a larger one with M12 bolts, so the prop depends on this.
I would think that a 4.1 diff will make first gear virtually useless, and leave you without an effective fifth.
brian325i
Sun Jul 08, 2007 1:07 pm
i will change the diff after a few weeks as soon as i have money for an lsd,3.64 or something but just wanna see what the short ratio's are like first.the standard e30 318is looks close just a little bit too long,might just get that shortened and a flange to match put onto it
Dave_M3
Sun Jul 08, 2007 1:34 pm
It'll be amusing with the 4.1 diff though :mad:
Theres a guy in Midleton thats pretty good at this kinda machining, reasonable enough too. Did the driveshaft for us in doing a Daf truck engine conversion at home for something, had to be made 7 inches longer.
Paul Murphy is his name as far as I know. He has a small machine shop just in on the right on a small road into a housing estate as you go over the bridge by the Distillary on the left across from Manic Motors. I'll try get his Number off my Dad later on.
Sun Jul 08, 2007 2:47 pm
3.64 is still too tall. It's the equivalent of running a 4.5 with an E30 box.
Look on the kit car forums for prop shaft specialists. Around £100 gets you a special made up and balanced.
hands
Sun Jul 08, 2007 6:11 pm
try e36 auto prop ? should go straight on .
brian325i
Mon Jul 09, 2007 12:58 am
the output flange is the bigger flange,i have an e30 and an e36 prop and the flange is too big for both,im gonna use the standard 318is prop and get it shortened a little,and change the output flange on the gearbox to an m42 item,i presume itll fit yes?
brian325i
Mon Jul 09, 2007 5:01 pm
will e30 m42 g/box flange fit onto the m50 g/box.splines and diameter the same???????
Mon Jul 09, 2007 9:35 pm
Couldn't be done with the flanges I tried to swap over once. Can't remember what the boxes were, other than one was originally attached to a M50 engine.
finny_325i
Mon Jul 09, 2007 10:39 pm
This is what you should do!, m52 g/box flange onto my m50 gearbox,then shorten my e30 iS prop and put the flange from a 325 onto the iS prop,both are 78mm.prop place close by
ok?
eko
Old timer
Tue Jul 10, 2007 12:07 am
Im using an E36 325/328 front half,E30 rear half and modifyed E30 centre bearing with no problem!
brian325i
Tue Jul 10, 2007 1:34 am
the flange on my gbox is the 96mm one,huge,toooo big for the e36 325 prop i got.i will just get one chopped and welded and balanced.when it started it had no manifolds on,some noise,scary 8O
