Wipers - is this a new problem?
Splod
Sun Jun 24, 2007 9:54 pm
Hi everyone and yes I know there's an piece about this in the Articles section - but I have a slightly different problem developed and I cant find any mention of it so thought I'd ask!
My wipers used to stutter every now and then on the intermittent setting and no, I never got round to sorting the problem out. They dont seem to do it as much lately. But now, a slightly different thing happens on the intermittent setting. That is that they start off intermittent but then suddenly change to full speed instead. Anyone else had this, and if so do you think it's down to the same problem? Sounds like it should be the switch to me?
Steve W
Sun Jun 24, 2007 9:58 pm
New one to me, but the stuttering on intermittent = arcing on the relay contacts in the wiper control module.
Maybe the arcing has built up the contacts and they are shorting out, so try a different control module (large black
rectangular 'relay' in the fusebox.)
JayB
Sun Jun 24, 2007 10:22 pm
also check the wiper motor conection the contacts fur up due to water getting in.
Splod
Mon Jun 25, 2007 7:55 pm
Thanks guys, I shall check both if it ever stops raining (dont need the intermittent setting at the moment...!)
