E36 Injectors into an E30???
- funky-monkey
I was wandering if anyone had done this? As the E30 325i injection system is getting on a bit now. Does anyone know if I could replace my current injectors with a lot from an E36 325i to maybe get a bit more power and make the system a wee bit more efficient?
- funky-monkey
shame, though if you don't ask you don't get. Thanks
- KINGOFSNAKE
some bloke on ebay said it was a good upgrade option, im glad you asked the question so now i wont be fooled
- funky-monkey
I saw the same add.
march109
- Contact:
all a load of bolocks they won't help at all, infact you'd probably run rich. the Egay fella doesn't know what hes talking about.
- funky-monkey
No slating intendid, I'm just not that technical and I am always looking for ways to make my car that little bit better. It's all good
HairyScreech
iv been told that the ecu isnt a learning type and that injectors or a different flow rate. either hiher or lower cc/min, will cause it to over or under fuel and need adjustment.
if thats wrong then im sure in the market for a new set of injectors for the m20b20.
- Kos
- Contact:
look at it this way if you feed a horse more food will it run faster ??
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
HairyScreech
you wont bee feeding it any more as the fueling has to be adjusted to suit otherwise it will just be running ritch.
lamba sensors been mentioned before, theory is it wont have a wide enough adjustment range to compensate. but this is yet to be tested.
- Kos
- Contact:
its the easiest way to make people understand
train the horse and give it the right things then it will get faster and stronger
IG Pukar.Designs
IG Pukar.Designs
kam-325i
- Contact:
It was me that emailed about the M50 injetcors having a greater flow rate.DanThe wrote:Yes its my ad![]()
Got a fair few sets I need to get rid of one way or another.
If you read closer though you will notice I recommend them for turbo or cc increased engines, no bullshit anywhere
- --alpina--
I have E36 M3 injectors in my car, the spray pattern is different, you will notice that when fitting the injectors it will over fuel, but take your car for a C02 adjustment back to how the previous injectors were, i done this cos i was the one who took the injectors outta the engine and it only had 3k miles on the clock and my injectors are new so i thought why not put em in, never looked back and had no problems... you can fit E36 2.8 injectors, M30 3.5 injectors, and ive know people to do that and works well.. im not condoning it as you can make your own mind up but like i says ive had no problems and the car runs sweeet, bear in mind i have a 2.7 reemapped with them on.....
goodluck
goodluck
