Axle Stand points when removing rear sub frame?
elebub
Fri Jun 22, 2007 1:59 am
I am in the process of replacing the rear subframe, where would you support the back end of the car? As you see in the pic one of the jacking points has been welded, is this still an option or is there somewhere else?
I have read a lot of threads about jacking points but none of them seem to answer this specific question. Any thoughts?
smithy318i
Fri Jun 22, 2007 9:32 am
march109
Fri Jun 22, 2007 9:50 am
Is ur car balancing on one axle stand??? I can't see what its under either.
elebub
Fri Jun 22, 2007 10:09 am
Thanks for the replies.
The car is up on ramps at the moment, the fun starts when I have to take the wheels off, hence the question. The trolley jack and axle stand were in position ready for lifting when I thought it looked a bit iffy.
smithy318i
march109 wrote:Is ur car balancing on one axle stand??? I can't see what its under either.
On the Chassis box section just behind the spring cup.
elebub
Fri Jun 22, 2007 10:20 am
Couldn't get the picture to work in the last post.
Trolley jack is under the sub frame mounting bolt and the axle stand is under the rear jacking point. I didn't release the trolley jack because it all looked a bit precarious.
elebub
Fri Jun 22, 2007 10:32 am
Thanks for the explanation smithy318i, I definitely need some taller axle stands.
