CAN ANYONE HELP !!!!!!!
E30Till
Mon Jun 18, 2007 3:58 pm
NEED TO NO HOW TO CHANGE A SUMP ON A 1983 E30 TECH 1
ALL HELP VERY APPRICIATED
THANKS
d6dph
Mon Jun 18, 2007 3:59 pm
Moving to the tech section.
Please do not type in caps either. 8)
Andyboy
Alpina Colada
Mon Jun 18, 2007 4:03 pm
They are a bastard. You need an engine crane to lift the engine up off its mounts and even then it won't clear the oil pump. So you need to drop the oil pump down into the sump and pull the sump out - don't forget the pump driveshaft.
E30Till
Mon Jun 18, 2007 4:05 pm
Wherecan i get a engine crane from ?
JohnnyThunders
Mon Jun 18, 2007 4:13 pm
Enginecranes R us
Naw sorry i dunno really. :D
ed325i
Mon Jun 18, 2007 4:20 pm
You can hire a crane from a hire shop.
Where are you from ?
orangecurry
Mon Jun 18, 2007 4:21 pm
E30Till wrote:Wherecan i get a engine crane from ?
machinemart do various rated cranes.
E30Till
Mon Jun 18, 2007 4:26 pm
From little dunmow Near stansted airport !
handpaper
Mon Jun 18, 2007 4:32 pm
Andyboy - you need less mechanical sympathy!
E30Till - it's not quite that bad:
Drain the oil!
Remove the plastic cover under the radiator.
Remove the bellhousing extension at the rear of the engine - 4xTorx bolts and 4x13mm hex head bolts. You can now see all the sump bolts.
Remove the oil level sender and engine earth strap from the right front of the sump.
Slacken ALL the sump bolts 1/2 a turn before undoing ANY of them completely.
It's probably a good idea to unbolt the radiator at this point - this allows it to follow the engine up, preventing stress on the coolant pipes.
With all the sump bolts out, remove the nuts from the bottom of the engine mounts and jack the engine up until you can wiggle the sump out. You may need a bit of wood on top of the jack, as it needs to go up quite a long way - if you have a strut brace fitted you'll need to remove it!
Clean the old gasket off - a sharp 1" wood chisel works well for this, but be careful not to cut into either the gasket face or your fingers :eek:
Stick the new gasket to the new sump, wiggle into position, check the gasket hasn't shifted, and bolt it on (finger tight until all bolts are in, then tighten in cross-pattern).
Drop the engine slowly, making sure the mounts are lined up with their holes as it goes down and replace the nuts on the engine mounts. Tighten to 'bloody tight'.
Replace the oil level sender and reconnect the earth strap.
Replace the bellhousing extension and plastic undertray.
If you unbolted the radiator, secure it again.
Refill with oil (this is a good opportunity to change the oil and filter :))
E30Till
Mon Jun 18, 2007 4:39 pm
Thanks for that mate you really sound like you now what you are doin. i have just brought the car and had a little rear end action in it moiunted the kerb and cracked the sump i brought a new 1 the weekend attempted to fit it but couldnt get to the last bolt which is above the subframe so decided to give up and ask about thought it was going to be a piece of piss but now i wish i had gone to a garage insted do you now anyone who can give a help in hand ?
Nelly
Gumbo
Gumbo
Mon Jun 18, 2007 4:51 pm
I can do it for you fella - i'm guessing i'm about 20/25 mins away from you in Ware, Hertfordshire.
If you want it done drop me a pm with your details or you can ring me on 07977 726577.
Neil.
"I F**KING LOVE YOU GUMBO"
AndyG
Mon Jun 18, 2007 10:23 pm
you're about 40 mins or so Nelly if you go via the A10/A414 & past the airport. Easy run though.
Andyboy
Alpina Colada
Tue Jun 19, 2007 8:32 am
handpaper wrote: and jack the engine up until you can wiggle the sump out.
And how exactly do you wiggle the sump out when the weight of the engine is on a jack? Where do you jack it up? Front pulley? winkeye
Use an engine crane and lift it. To get the sump off without removing the oil pump is a nightmare - the oil pump is just some 13mm bolts so you may as well do it properly and not risk buggering it. I've done this a couple of times on a ramp and it's a cow of a job.
Also make sure you get a proper 'hard' sump gasket and not one of the shitty cork ones that pop out.
Tue Jun 19, 2007 9:05 am
Can't agree with you here, Andyboy. I've never had any problem removing the sump on a M20 once the engine mounts have been undone and the engine lifted.
Alternative way is to support the body and drop the front subframe down.
Andyboy
Alpina Colada
Tue Jun 19, 2007 9:35 am
I'm not saying it can't be done - I'd just rather drop the oil pump that risk straining something! Dropping the pump down just makes it a bit easier.
Nelly
Gumbo
Gumbo
Tue Jun 19, 2007 6:00 pm
AndyG wrote:you're about 40 mins or so Nelly if you go via the A10/A414 & past the airport. Easy run though.
That's the way fella, cheers - i used to deliver to the "Dunmow Inn" though i guessing it's not there anymore due to it sitting on a huge piece of land and housing seems to be at full flow around the A120
Nelly
Gumbo
Gumbo
Tue Jun 19, 2007 6:41 pm
Actually - i'll go North A10 then East A120, quicker that way.
Andyboy
Alpina Colada
Tue Jun 19, 2007 8:12 pm
Sounds like a sump gasket in progress then!
