Instrument cluster ground point
browny
Post Thu Apr 21, 2005 6:51 am
Hi guys. just a quick one. Where is the ground point for the instrument cluster? I have twitchy temp and fuel gauges. Done the whole tighten nuts clean contact points on the actual circuit board, so was wondering if it is a grounding problem on the car somewhere. Thanks!
Post Thu Apr 21, 2005 8:08 pm
G200 stud and nut behind glovebox.
Try a different SI board as well.
willow
Post Sat Apr 23, 2005 4:54 pm
Brian, is this nut easy to get to?
Save the E30s!
Post Sat Apr 23, 2005 5:43 pm
Push the pins out of the glovebox straps and let it hang down. Then remove the plastic panel above the glovebox. Two 1/4 turn fasteners and a couple of self tappers.
Earth stud(s) is in the middle at the back with lots of brown wires going to it.
willow
Post Sun Apr 24, 2005 11:18 am
Cheers Brian....fountain of knowledge :D
Save the E30s!
