obc code plug
gazza
have now fitted the correct coding plug to my obc ....the readings were a bit out before but now with the new plug they dont seem any different do you have to do a sort of re-set on the obc to get it to recognise the new code plug ...ie battery off for a few mins or should it spot it and sort it itself
design cab and now 325 touring-
nadz325i
hi
there is some sort of adjustment on the obc for the range button and amount of fuel left in the tank.
it located on the bottom left of the obc, i think its a phillips + screw driver small one tho, that might need to adjusting. ive currently replaced mine and ive got like 20 quids worth of fuel and it telling me ive got 30 miles range haha crazy obc.
rockwell
Hi Gazza
Have you managed to get the correct figures with the new coding plug. Would like to know before I order one.
gazza
no not yet ive been away for the weekend but i will try this week if yours is a m40 1.8 then i can confirm it is the right plug it is marked typ 4.02 as opposed to 4.2 i have the part number if you need it and was suprised to see it was manufactured in august 04 ....so they are still making them
smithy318i
where can i get a plug for my 318i ?
and why can i only have miles with temp in F
or temp on C with km
(i want C & miles / mpg)
gazza
from the dealers they are still available ....the part number is on a previous thread a couple of weeks back...mine is the typ 4.02 plug for a m40 1.8....as for the other questions i dont know
smithy318i
price?
rockwell
Hi Gazza
After changing the coding plug are you now getting the correct figures for your car. I would like to know if it is giving the correct figures.
dazleeds
- old skool raver
mines also giving me random stupid figures how much is a new coding plug?? also does anyone know how much the new code plug is that goes in the instrument cluster??? got crazy rev readings as well
sticking rev needle etc cheers Daz leeds
www.oldskoolfantasy.co.uk
gazza
my obc code plug was about 25 pounds it was ordered by the dealer from germany and arrived within 3 days it does work my only gripe is the consumption figures. it never gives figures doing better than 16.2 mpg when i know it does at least 25mpg the speed is right because your own speedo is never accurate as it only has to read within a percentage of true speed to comply with legislation at 100mph on the speedo it was showing 89.4 mph on the obc which i would say is right. everything else is ok
