AIR FLOW METER TO MAF CONVERSION
- WARLOCKM42
- Contact:
Hi guys i want to get rid of the airflow meter on a m42 engine got any sugestions? If i find a maf whith the same output voltage will it work? I think that if i get a maf or map sensor that works on the same voltage my airflow meter does and use a temperature sensor simillar to the one my airflow meter uses then the ECU will have the same iformation it gets from the airflow meter.Correct me if im wrong.I know SPLIT SECOND offers a kit but it costs almost 1000euros =678GBP.I Need to find a cheap clever solution that every beemer maniac can share!!! HELP me over here guys!!! Many many thanks
- wullie325i
- CAUTION - unreliable trader!
well thats a kick in the bollox
- wullie325i
yeah but i might be getting one...........
