Calling Fire Extinguisher owners.
gazm3
Sun May 27, 2007 9:05 am
Just purchased a Fire Extinguisher.
I believe it was boot mounted in a touring, Is this normal?. Any photo's.
The standard position as far as I know is under the drivers seat. With a bracket that I dont have!.
Are the under seat brackets still available from BM?.
Just like this one on Ebay.
http://cgi.ebay.co.uk/BMW-Fire-Extingui ... dZViewItem
Could someone with said extiguisher post up some quality photo's as the OEM doesn't have any details or diagrams.
Cheers Gareth.
gareth
Sun May 27, 2007 9:20 am
afaik they were all mounted on the underneath of the seat.
i have an aftermarket one (much much larger) fitted there as the original ones are a bit small.
--alpina--
Sun May 27, 2007 11:28 am
:D i had 4 of those which i took of a mate who use to buy and scrap bmws for parts e.t.c., must admit the guy on ebay is behonest with th statement " i would not trust it to put out a fire being about 17 years old " hes right cos i opened all 3 bottles to squirt and nothing came out with pressure allthought they were new and full, it did squirt but very low from the nozzle, now im not sure you can get them refilled from BMW as they might have to get them sent away!!, just go down to halfords they have loads of different sizes... i have one that i used to bolt in the front passenger on the side of the center console..., but now am going to route it to the boot,,,,
jimi
Uk`s first E21 - Forum -
http://www.e21.ownforum.org
gareth
Sun May 27, 2007 11:42 am
mine is a halfords job. the holes didn't line up exactly so a but of 1/4" ali plate with 4 holes in sorted that. it's all hidden under the seat bolster anyway so you can't see that it's not factory fitted unless you're a brake pedal!
gazm3
Sun May 27, 2007 12:10 pm
This is what I have:
I need the bracket!.
DaveD
E30Zone Wiki Specialist
Sun May 27, 2007 2:27 pm
the bracket is available it says ...and so do pelican...about £26 from the stealers
http://www.realoem.com/bmw/showparts.do ... g=72&fg=95
eko
Old timer
Sun May 27, 2007 2:30 pm
gazza325cab wrote:This is what I have:
I sold Tylerma the part you need recently,maybe he didnt use it?
Worth a PM maybe?
gazm3
Sun May 27, 2007 2:42 pm
Thanks for the help guys.
That bracket looks different on the OEM to the one on Ebay.
Someone go to there car armed with camera to sort this out!.
eko
Old timer
Sun May 27, 2007 2:46 pm
gazza325cab wrote:
That is definately the bracket you need!
Dan318-is
Sun May 27, 2007 2:50 pm
Agreed ^^ Mine is mounted under the seat and the bracket is the same as that!
Martinaston
Sun May 27, 2007 3:11 pm
Does anyone know how much a new original extinguisher costs ?
There is NO nucleus.
Templ8e30
Sun May 27, 2007 5:17 pm
The bracket on realoem is just the bottle carrier, the curved bracket for the seat (that the bottle carrier bolts to) has been NLA for a long long time.
The curved bracket bolts to the seat base with 4 screws, the bottle carrier then bolts to this with 2 screws.
If you have the seat bracket the new style extinguishers (with new bottle carriers) from BMW fit perfectly.
New extinguishers are about £35, part number 72600000335 Iirc.
Get bidding.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Chris-W
Sun May 27, 2007 5:22 pm
Here you go - this is the E30 set up:
Re PM, Gareth - I don't have a separate spare bracket, sorry! Unless anyone needs an extinguisher?
Simon
Sun May 27, 2007 5:35 pm
Gareth, sorry :o: I hadn't seen an extinguisher for a while since I sold my old sport, and forgot about the extra bracket.
Where it was mounted in the boot on the touring was not a standard place for mounting.
eko
Old timer
Tue May 29, 2007 4:40 pm
gazza
Tue May 29, 2007 9:02 pm
my touring had one from new fitted to the drivers seat...i have asked at bmw and the bracket is nla and you may find the current extinguisher is different .....i asked if it could be re-filled and was told no ...but im sure there must be a private company somewhere that can do it
gareth
Tue May 29, 2007 9:59 pm
you're all being over tarty!!! mine is a lot larger, is full, is new and cost me £15 with the bracket!!! it's not a bmw one but then i doubt bmw themselved made the oem ones... :D
Chris-W
Tue May 29, 2007 10:03 pm
gareth wrote:but then i doubt bmw themselved made the oem ones... :D
Nonsense. They were individually hand-crafted by shareholders and family members.
gareth
Tue May 29, 2007 10:11 pm
peejay
Wed May 30, 2007 12:22 pm
eko wrote:Gareth,ive got a spare bracket/holder here if you want it.£15 posted!
Seems reasonable.
Life begins at 40 ( to matter!)
sam325is
Thu May 31, 2007 9:09 pm
i have the new e30 set up on my car. you need the old bracket as it is 2 piece. you need the piece that attaches to the seat and the piece that actually holds the extinguisher you dont need as when you buy a new one from bmw it is updated so you have a new holder which attaches to the old bracket which attatches to the seat. the new extinguisher is slightly larger.
the new extinguisher bracket comes in the box with the new extinguisher so no need to ask for a seperate order as they wont find it.but dont order it unless you have the old bracket as you will be :x
