When I look at the back of the car the right hand rear has a camber but the left is dead straight, I replaced the back shocks which were about an inch longer than the one's I took off, and the front passenger shock is fooked. Would the fooked front shock and the fact that the new rears are longer be causing this or is there someting else.
Cheers.
Camber on one side, ?
how can you tell if it's bent or not? I'm starting to suspect it's the same with my touring, drivers side rear wheel is badly worn on the inside... so much for "oh, car is perfectly fine" from a zoner who should have known better
