Steering Coupling
chief
Tue May 01, 2007 5:07 pm
Just had a look at the steering coupling on my e30 325i
the coupling itself seems to have plennntttyyy of play in it, and there seems to be a very minor wobble sometimes in my steering wheel
BUT
i'm not sure if it can be tightened or i need a new one. i have attached a couple of pictures if i'm not explaining well.
it looks like there are 2 bolts, 1 near the rack & 1 near the bulk head.
http://i6.photobucket.com/albums/y203/r ... ing002.jpg
http://i6.photobucket.com/albums/y203/r ... ing001.jpg
anybody else had any bother with this, not heard anything from anyone about this before.
Don't you wish there were a knob on the TV to turn up the intelligence? There's one marked 'Brightness', but it doesn't work.
Chris-W
Tue May 01, 2007 5:14 pm
Difficult to confirm from the pics, but it does look like it has gone. The rubber doughnut in the middle of the coupling goes. Fairly common problem, but on the bright side your car will feel much better when it's sorted!
I'd suggest a good used one, but then I would because I'd also try to sell you one. You can get re-build gets from BMW, and complete couplings too.
chief
Tue May 01, 2007 5:16 pm
thanks chris,
yes its definitely the rubber doughnut where the play is. :)
GBE30
Thu May 10, 2007 3:54 pm
Hi,
Guys what kind of job is the above to change?
I would like to give it a go myself. Any tips pointers etc?
Gareth
You don't win friends with salad...........
Thu May 10, 2007 11:41 pm
Take out the pinch bolts on either end of the coupling, slacken the LH steering rack mounting bolt slightly, and remove the right hand bolt completely.
Swing the right hand side of the rack forwards and remove the coupling. Open up the splines slightly by driving a screwdriver in the 'pinch' gap if either end wont slide off.
If the coupling is original, the rivets will have to be ground out to remove the flexible disc. New disc comes with nuts and bolts instead.
Stick it all back together and check that the steering wheel is on straight.
GBE30
Fri May 11, 2007 8:00 am
Thanks Brian, Is there anything you do not know??
Gareth
