Post
Sat Apr 16, 2005 12:06 pm
Slide the hand brake grip off the actual lever (Bloody hard work, lots of twisting whilst pulling required) and then pull the old rubber gaiter away from the console at the bottom - It just unclips.
If you need to remove the rear half of the centre console (I don't think you will BUT...!) it's easy - Just remove the rear ashtray and you'll uncover two bolts. Undo these and lift the rearmost part of the console first, it'll slide out from where it joins the front part of the console.
Hope this helps.
1989 BMW 320i 2.7 2 door saloon
