rear wheels bearing and hub
- E30Zone Contributor
im tryn 2 do my rear o/s wheel bearing got it all stripped but cant get the hub off haynes say hit with big socket or pipe tried that for a hour 2day and just cant get it to move any ideas or help from anybody whos done this before cheers
The hub of a drum brake, keep bashing it from different angles it wiggles off eventually, the bearing is a bitch tho, i smashed fook out of it while under the car for hours,, nothing. Took the trailing arm off, layed it over, a 32mm socket and a sledge later and it was out
cheers mate any other ideas guys dnt want to take trailing arm off etc
- Contact:
Have you taken the big circlip off?
no cant get to it because the hub is still on.
- Contact:
So you haven't got the Drive flange off, rather than the hub?
- Contact:
