i have an early 320i m20b20 and the idle is hunting between 750 and 1000rpm when fully warm. the other threads i checked suggested several possible faults which i went through
TPS: checked with a multimeter according to the instructions in haynes, it clicks and has the resistance that haynes describes
air/vaccum leaks: went over the pipes and found nothing
ISV: on this one haynes wasn't very helpfull and i searched for ages before i found what i assume is it down by the starter
tested it on a battery and it clicks when current is applied. reconnected it and started the car, then used two "jump" wires to the battery to operate it manually. when current was applied the car idles at a steady 1200rpm.
another thread mentions a connector plug under the inlet manifold where the terminals corrode but i can't for the life of me find it
this has pickled my head and im unsure what to do next, any help will be greatly appreciated
