trouble removing my engine, bluddy g.box
325i-sport
Post Mon Jan 17, 2005 3:16 pm
i have got one more gear box, torx bolt to undo and its the one right on top of the gear box. i have undone the g.box mounts and the engine mounts, to lower the box down to able me to fit a rachet on top of the box but everything is real tight it took me about 3 hours yesterday to remove the top side three bolts. has anyone got any tips or anybody know of any special tool or way to un do this bolt. cheers guys
E30Adam
Post Mon Jan 17, 2005 3:56 pm
325i-sport wrote:i have got one more gear box, torx bolt to undo and its the one right on top of the gear box. i have undone the g.box mounts and the engine mounts, to lower the box down to able me to fit a rachet on top of the box but everything is real tight it took me about 3 hours yesterday to remove the top side three bolts. has anyone got any tips or anybody know of any special tool or way to un do this bolt. cheers guys
I've never had a problem with these on any I've ever undone, just get a large bar on the end of your socket and extensions and twist it off.
Alternatively, go to Halfords and buy a torx spanner, you can just about slip it over the bolt and then I find a jack handle fits nicely over the spanner and you can undo it fron the top, makes life much easier!
325i-sport
Post Tue Jan 18, 2005 1:02 pm
the bulk head is realy close to the inlet manifold and i cant fit a spanner down there.
i have putextension bars onto the socket but i havent got enough room to turn the rachet due to the tunnel being that little bit too cloese to the box. im going to assess it tonight and give it another go, i was a bit miffed off last time as it was cold wet and i was outdoors in the dark with a torch. so with a bit of luck weather permitting i should have it off tonight. cheers anyway adam.
randomdave325
Random E30 Nutta
Post Tue Jan 18, 2005 1:13 pm
just undo thr prop (3 bolts), the prop centre bush (2bolts) to allow the prop to drop, the gearlever rear mount (1 bolt) and the slave cylinder(2bolts) and pull the lot out. i've struggled with this before and found this to be a loads easier way to get it out/in.
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise' :)
SCOTT325SE
Post Tue Jan 18, 2005 8:48 pm
this should be a piece of p1ss! try a "knuckle" socket bent back towards the front of the engine bay and a ratchet! comes off easy! (i got mine out with a halfrauds torx spanner as adam mentioned. no probs for me. :)
Post Tue Jan 18, 2005 10:48 pm
Read somewhere once IIRC, that if these bolts have been fitted without the thin steel washers in place at some time in the car's previous life, then they become VERY hard to undo.
